Results 1 to 10 of 13
Thread: Something has gone wrong
    Default Re: Something has gone wrong
    Since your chlorine has been way too low, I suspect that algae is the problem. You can verify this by testing for chlorine at night and again in the morning, to see if you're losing any chlorine overnight. At any rate, the answer is to add chlorine, and lots of it. With a CYA over 100, this means taking your chlorine level up to 25 ppm and holding it there until the pool clears up, and until you're no longer losing chlorine overnight. At that point you can let the chlorine come back down, but with your CYA that high, you can't ever let it come down below 8 ppm.
    I don't see your results in the pool chart, so maybe it didn't save. When you get a chance, could you please fill it out again?
    Aug 2012
    Oklahoma
    I have tried 4 times but here are the answers
    Own the pool
    Oklahoma
    race9899
    16 round 3.9K gal Intex AG vinyl pool; hand fed granular; Intex cartridge filter; Intex 1 speed pump; 24 hrs; ; HTH 6 WAY Test Kit Drops ; utility water; summer: none; winter: none; ; PF:31
    All 4 of your entries were in the data table -- I deleted 3 of them. It's possible Janet was looking at a slightly out of date back up copy of the Pool Chart data.
    In any case, the information is now in your signature.
    Aug 2012
    Oklahoma
    Thanks...
    Aug 2012
    Oklahoma
    I let the pool settle, vacuumed bottom with pump not putting water back into pool, add 6 cups of bleach, pool is still green but much lighter and cloudy.
    Should I have the water tested at a pool supply?
    If you have green, you need to increase your every evening bleach dose to 1/2 gallon of PLAIN 6% bleach -- that's about 15 ppm on your pool
    AND . . . you need to retest your pool BEFORE you add the bleach, but be SURE to test and report the CYA level. That's critical. If you want to understand why, read the Best Guess page linked in my blue signature block.
    Aug 2012
    Oklahoma
    Pool is finally not green but cloudy.
    Had water tested...
    Total Chlorine 8.2
    Free Chlorine 7.6
    PH 7.6
    Total Alkalinity 90
    Calcium Hardness 145
    CYA 151
    I should add more bleach?.. We added 10% volume of water after these test's..
