Results 1 to 10 of 13
Thread: Something has gone wrong
    Aug 2012
    Oklahoma
    Default Re: Something has gone wrong
    Pool is finally not green but cloudy.
    Had water tested...
    Total Chlorine 8.2
    Free Chlorine 7.6
    PH 7.6
    Total Alkalinity 90
    Calcium Hardness 145
    CYA 151
    I should add more bleach?.. We added 10% volume of water after these test's..
    16 round 3.9K gal Intex AG vinyl pool; hand fed granular; Intex cartridge filter; Intex 1 speed pump; 24 hrs; ; HTH 6 WAY Test Kit Drops ; utility water; summer: none; winter: none; ; PF:31
    Are those results from your HTH kit or from a pool store? If your CYA truly is that high, your shock level will be 25ppm. (See the Best Guess Chlorine Chart in Ben's signature above for info about the correlation between CYA and chlorine levels.)
    Aug 2012
    Oklahoma
    That was from the the pool store..
    We have been adding over a quart of bleach per night
    Quote Originally Posted by race9899 View Post
    You have the 6-way, right? You need to test it yourself! Unless you make a mistake, it will be more accurate than the pool dealer.
