Hi,
Weekly shock treatments are not required--in fact, the only time you need to shock the pool is if you start seeing CC levels higher than 1.0, start losing chlorine overnight, or start having increased amounts of chlorine loss during the day. This all requires, though, that you be able to accurately test your own water. Test strips are not accurate enough to do this for you--you seriously need a drop-based kit. If you don't have one, the K-2006 linked in my sig is a really good one and will test for most everything you could possibly need.
Algae control treatments are also not necessary, except in a very few specific conditions, like a pool with a high metal content. A properly chlorinated pool will not grow algae--and if it's not properly chlorinated enough to keep algae from growing, it's not sanitized enough to be swimming in, anyway.
That being said, my climate is very close to yours, and if you're using an autofeeder (trichlor pucks, I assume?) then your CYA levels are probably very high, and you will definitely need to keep a close eye on your chlorine levels in order to keep the algae gone, since as your CYA levels rise, so must your chlorine levels. (Again...you are not going to be able to do this without a good test kit......). Some folks use the algae treatments and weekly shock routine to compensate for not keeping the chlorine high enough during the rest of the week, and sometimes that will keep the pool clear, but the best way to keep the water clear is to test and treat the water based on your test results. Your CYA and chlorine levels are explained in the "best guess chlorine chart" linked in my sig (might have to log out to read it until your registration is completed), your pH needs to be 7.2-7.8, your alk around 100-120 if using trichlor pucks, and your CH level will depend on what type of finish your pool has (vinyl liner, plaster, gunite, etc.)
If you'll fill out this short form with your pool info on it and list a set of test results, we can help you devise a plan to keep your pool clear.
Pool Chart Entry Form
Welcome to the forum!
