Thread: Pool Algae
    Aug 2012
    South Louisiana
    Default Pool Algae
    Have a algae problem that won't go away. I have a 18 x 33 above ground pool holds 15,550 gallons water. I use the pristine chemicals.I have spent so much money on chemicals vacuum pool to waste still algae comes back.Any help greatly appreciated.
    Default Re: Pool Algae
    We'll be glad to help you get it cleaned up, but to do that we need a set of drop-based (no strips!) test results on your water, and a list of what you've put into the pool (ingredients, not product names like "shock").
    membership upgraded . . . but if you're using Pristine Blue, conversion can result in stains if you aren't careful.
    As Janet told you, valid test results are essential to a clean conversion AND to cleaning up the algae.
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Stickbox, not sure about your water cost or if you're on a well but it might be more cost effective for you to drain and refill. It cost me about 55 bucks in city water to fill my 30 foot AG pool this year. Where are you close to? I live close to Hammond.
    30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
  1. Mud and algae in pool
    By Texjag in forum In-Ground Pool Construction and Repair
    Last Post: 06-25-2012, 09:38 PM
  2. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Green algae? Mustard algae?
  5. Green Algae in IG Pool
    By LoveToSwim in forum Dealing with Algae & Slime
    Last Post: 05-10-2006, 05:03 PM
