Results 1 to 10 of 11
Thread: Low PH problem
Threaded View
    Aug 2012
    Indiana
    Default Low PH problem
    Long time pool owner with a new problem that I have never faced before.
    I have added almost 50 lbs of Soda Ash to the pool this season trying to get the PH up to 7.2. Nothing seems to work. In the past 30 years I have always fought high PH and added acid to bring it and the total alkalinity down.
    My daughters pool (vinyl) has had the same problem although my neighbor's (fiberglass wall cement bottom) pool has not.
    Central Indiana has had an exceptionally hot dry summer like a lot of the country. With the low PH my daughter and I have been going through chlorine like mad. My pool has remained clear while her's is cloudy, white cloudy not green cloudy.
    Any suggestions to get the PH in line before we start to close the pool in about 3 weeks?
    19x37 oval 21.9K* gal IG vinyl pool; trichlor feeder; Hayward S244T sand filter; Hayward 1 HP 1 speed pump; 24 hrs; ; Pentair 78HR drops; utility water; summer: solar; winter: vinyl / water bags; Laptop; PF:5.5
