Re: Help!!! Pool is green. Bad!!!
Don't add any stabilizer.
Read this thread on using muratic acid to lower your PH: http://www.poolforum.com/pf2/showthr...light=lower+ph
Lower your PH, keep chlorinating to get rid of the algae then worry about all the rest.
Also, what type of pool do you have? Is it gunnite, fiberglass or vinyl and how are you testing your water? Do you have a K-2006?
30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
