Results 1 to 10 of 14
Thread: Replacing a liner in a 16x32' inground pool
    Default Re: Replacing a liner in a 16x32' inground pool
    An AutoCAD calculation would be WAY more accurate. The algorithm used on the Pool Chart is my own, and makes the following assumptions:
    1. Break begins 1/3 of the distance from the shallow to the deep end.
    2. Hopper bottom (straight slopes) rather than bowl bottom.
    3. Actual water level is 6" below listed depths.
    It does not account for a 4" - 6" shelf around the deep end.
    Pool salesmen consistently over-estimate pool volumes, as a sales tool.
    Aug 2012
    Massachusetts
    Thanks.....great to have a closer approximation of the actual water in the pool
    Raising the bottom will decrease the volume even more......easier to solar heat the pool
    16x32 rectangle 16.6K* gal IG vinyl pool; Chlorine; Hayward Pro-Grid DE4820 Vertical Grid DE filter; Hayward 1.5hp SP3010X AZ15 1 speed pump; 4/8/2012 hrs; solar heat; drops method; Rainwater; summer: solar; winter: mesh; none; PF:7.2
    Quote Originally Posted by DIYLINER View Post
    Not as much as you think -- most of the heat loss in an AG pool is from the surface, and 2nd most is from the top 12" the pool sides.
    Aug 2012
    Massachusetts
    Actually it will make quite a difference, since we have a stream on the property & groundwater flow
    The groundwater flow constantly cools the bottom of the pool
    The 1st year we lived here we hardly used the pool as it was too cold
    With solar heat the 2nd year temps were in the 80's
    Insulating the bottom against the ground water flow will make a big difference, just wish the whole pool had been insulated when installed
    Insulating a pool can make a difference, but it's still true that your major loss is via the surface.
    Aug 2012
    Massachusetts
    I had a cover the 1st year we moved in, I did not have solar heat
    In my case the major loss of heat is thru the ground
