Results 1 to 3 of 3
Thread: Algae problem
    Aug 2012
    South Louisiana
    Default Algae problem
    My local pool store told me to add 2 quarts of muratic acid wait 1 hour add 10 lbs. of shock wait 4 hours. Move pump to recirculate add 4 lbs. of Phos Floc circulate 2 hours then turn pool off wait 1-3 days then vacuum to waste.Backwash/rinse then shock again to get rid of algae. Is this accurate & do I add the muratic to the skimmer or directly in the pool & keep the pump in the filter section. Thanks
    18x33 oval 21K* gal AG vinyl pool; pristine chemicals; sand filter; 2 speed pump; hrs; ; pool check 6in1; utility water; summer: none; winter: none; none; PF:5.6
    Default Re: Algae problem
    I would run, not walk, away from whoever gave you that advice!
    To kill algae, you just need to raise your chlorine levels to "shock" level, which is determined by your CYA. If you can get an accurate set of test results on your water, taken with a drop-based kit and not strips, and post them here, we can help you get it cleaned up.
    We also need to know a little about your pool, like what you normally use for chlorination, and a list of what's been put into the pool (ingredients, not product names like "shock"). If you'll take a few seconds and fill out this chart with your pool info, that will help us help you, too.
    Pool Chart Entry Form
    Welcome to the forum--nice to see another Louisianian join the group!
    membership upgraded.
  1. Hello! I have an algae problem
    By poolnoobie in forum Dealing with Algae & Slime
    Last Post: 08-22-2012, 02:25 PM
  2. Algae problem. HELP
    By rollinrock in forum Dealing with Algae & Slime
    Last Post: 05-28-2010, 08:40 AM
  3. Help with my Algae problem
    By tonecold in forum Dealing with Algae & Slime
    Last Post: 07-07-2007, 04:33 PM
  4. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
