Results 1 to 10 of 26
Thread: Can cracked PVC be repaired?
    Virginia
    Default Re: Can cracked PVC be repaired?
    Quote Originally Posted by jwhouse View Post
    Jim, I'm not sure about marine epoxy but something that was made for use on PVC might. As for the amount of or speed of leakage, I don't think it would matter when attempting to patch it. Any pressure forcing even the smallest amount of water past the glue during the patch phase could cause channeling in the patch spot and allow the leak to continue.
    If I were going to try to patch it temporarily, my steps would probably be something along the lines of:
    1) Turn pump off to remove as much pressure as possible. Also close any valves that would prevent any natural pressure from the pool itself.
    2) Apply a portion of the Rain-R-Shine PVC glue to the affected area.
    3) Attempt to bond the two sides of the crack together with a small piece of PVC cut off of of some spare pipe.
    4) Secure it with a hose clamp around the cracked area to relieve tension from the outward pressure
    5) Allow glue to cure for at least 15 minutes before reapplying pressure.
    One more thing to consider would be that the reaction the glue has with the PVC during application, the more glue you use the weaker the PVC will become so this wouldn't be a "the more the better" scenario.
    Remember, all this is definitely not a recommendation but merely a thought thread on the possibility of patching the crack. My actual recommendation would be to replace the collar.
    Thanks for the great tip.
    Would you suggest I remove the flow switch before trying the repair? Or is that likely to cause more problems when I try to reinstall it? Also, I'm guessing I should leave the hose clamp on to counteract any outward pressure? And do I need to use PVC cleaner before applying the glue?
    Thanks again.
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Unless the flow switch is in a place that would require the glue to be put on it, I would leave it in. If you will end up with glue on the flow switch without removal, I would take it out.
    As for the hose clamp, yes, leave it on.
    Hope it works out for you. Will be a cheap temp fix with very little labor involved so even if it doesn't work, the worst case scenario would be that you have to replace the collar anyway.
    Let me know how it turns out.
    30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
    Virginia
    Thanks.
    While you were posting, I added this question;
    Do I need to use PVC cleaner before applying the glue (like you would when connecting PVC pipes)?
    Jun 2012
    Southeast Louisiana
    I doubt it will matter for this.
    Virginia
    Thank you everyone for all the great suggestions. I'll let you know how it goes.
    Virginia
    I found this:
    http://www.itwconsumer.com/projects/...g%20PVC%20Pipe
    Says it will fix leaks in PVC.
    Anyone have any experience using this?
    I have never had any putty epoxy last in a pressure side leak.
    I have found only one product that works to repair PVC and stands up well to pressure side leaks. It is called Plast-aid. I have used it successfully several times now and have not had it fail but it does take a bit of practice to get used to. It cures in about 15 minutes to repairs are fast.
    http://www.plast-aid.com/
    Their website has some excellent demo videos of how to use it.
    The nice thing about it is that you can apply it as a glue or a putty so it can fill a crack. My only advice is use it outdoors if possible since the smell is really strong until it cures.
    If you have a friend who is a pipefitter, most outfits today have a plastic welder and PVC rods. Cracks like you describe can be partially ground and then refilled. It does require a deft touch however, since there's a pretty fine line between melting PVC and burning it.
    Virginia
    Thanks for all the great suggestions.
    I decided to give the Plast-Aid a try. I'll report back after I receive it and do the repair.
    Get the middle or big kit so you can practice with the stuff first. Make a marble (the vid is on the website) so you can get used to it. I have not only used to to repair pvc, I have also used it for countless repairs on my RV
  1. Step-by-Step Account of Fiberglass Pool Crack Repair
    By Bosco390 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2014, 08:59 PM
  2. Can a hole be repaired in a fiberglass pool?
    By cnk in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2013, 09:59 PM
  3. Repaired Leaking Return Fitting w/o Draining Pool
    By eagle670 in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2012, 07:58 PM
  4. some vertical wrinkles in repaired vinyl liner
    By famdog in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2007, 04:16 PM
  5. Newly repaired pool has cracks!
    By Amir in forum In-Ground Pool Construction and Repair
    Last Post: 05-31-2006, 01:25 PM
