Thread: Is there a solar cover that is less likely to blow off the pool?
    cnk is offline ** No working email address ** cnk 0
    Default Is there a solar cover that is less likely to blow off the pool?
    Our solar cover always seemed to blow off the pool or to one end. We are looking to get a new one. Is there anything that can be done to prevent this? Would a thicker cover be more effective?
    Default cover issues
    Is your cover hanging over the edge of the pool so wind can get under??
    My pool is situated in the middle of a 5 acre field, we get super stong winds frequently, it hasn't so much as lifted.
    When I cut it to size, I made sure that is sat flat on the water, then trimmed it so there is approximately 1" of gap between it and the wall of the pool, I cut two slits for the step posts that are 2' in the pool and a couple of 2" circles where the poles will protrude through, so the whole thing sits flat on the water.
    Default
    Yes it lays flat. It has been cut to fit, but the jets always seem to push it to one end or the wind blows it. It is a cheap one from Lowes. I wondered if a more expensive, heavier one would do better. We also live in the middle of 5 acres of a flat field with heavy Oklahoma winds. Our house was newly constructed, so there are now trees or windbreaks.
    Default Ditto
    Same here on all counts!
    Mine's a good quality mid grade cover.
    Do you have steps with handrails and posts? If so, try adding some clips to lock it around the posts of the handrails, this may stop the movewment.
    Default
    Unfortunately no handrails or posts.
    Default weight...
    You could try clipping stainless steel washers onto the perimeter of the liner every few feet as extra weight to keep it down - feherguard makes really nice clips that could pinch a washer onto it perfectly
