Results 1 to 10 of 13
Thread: Yellowish dirt
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Yellowish dirt
    Lately I've been getting a yellowish dirt build up on the bottom of my pool, not on the sides but kind of scattered, anywhere the return does not directly flow.
    It wasn't there a month ago, I think June/July I only had to vacuum two or three times, now it seems I vaccum it up and then the next day or two It could use another vacuuming. It's almost like a sand.
    My kids are not in it as much but seems like more build up.
    I tested the water and my chlorine came back good, pH was about 7.5, and alk was 7.
    Any suggestions
    thanks
    Barry
    Jul 2012
    Mexico, Missouri
    Default Re: Yellowish dirt
    You know the Mods are going to want numbers...I assume you have the Taylor K-2006?
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Gave the numbers I have, chlorine, ph and alk.
    What else??
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Can you touch it? If you can touch it, try to pinch some between your fingers and look at it out of the pool. Does it feel like sand or is it of a more fine consistency than sand?
    If you can't touch it, does it seem to disappear when you try? Are your walls or floor slick or slimy to the touch?
    Is your water clear or other?
    You didn't actually give a number for chlorine. Only that it "came back good". How are you testing? Using strips, OTO or titrating drop kit?
    Sorry for all the questions but it's hard to give you an answer with such little info.
    30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
    I'll go into pool later, but for now, the kit I'm using is a HTH kit, ..OTO and the chlorine by view looks to be 5 or higher, water is clear.
    Do I have too much chlorine in???? Did I need an algaecide or just shock and if algaecide what type???
    Barry
    Whether your chlorine is "good", "too much" or "too little" depends on your stabilizer level, which you haven't reported yet. If you can get us that, using the disappearing dot test rather than strips, then we can better help you.
    The best algaecide you can get is chlorine--and lots of it. Whether you just have dirt/pollen or actual algae growing is sometimes hard to tell, unless you can measure how much chlorine you're losing overnight when the sun isn't out.You can't measure that accurately with an OTO kit, which is why we recommend the K-2006 kit that can be found in the link in my sig.
    HOwever, at the very least, we're going to need to know your CYA level to help you with your questions...
    I only had two test (dot) in my kit for cya , being the end of the season don't want to go out and buy a whole new kit. So maybe I'll just go on the guess that I need more stabilizer and put that in, it's been awhile. But wouldn't my cl level be low if I needed more stabilizer???
    Jul 2012
    Mexico, Missouri
    Not necessarily. Usually, whatever you had for CYA will be close to what you have now. It doesn't drop on it's own. You can get more reagent from Amazon, or go directly to Taylor website and order it. The Walmart HTH kit is a rebranded Taylor kit. The reagent you want is R-0013. Best to get the 2oz bottles.
    If you know your CYA level, you can use the Best guess chart to determine your ideal FC level.
    There is a way to use the OTO kit for measuring higher than 5 on your chlorine, but I don't have the link handy for those instructions. Be aware also that this method isn't that accurate, but is better than "guess strips".
    Now you know why the Mods here are always pushing the Taylor K-2006 kit. You would be money ahead to purchase it, through the links from any of the mod's signatures.
    Here is the dilution method that Charlie was referring to:
    Testing Without a Good Kit
  1. Old plastic water outlets and skimmer are old and ugly (yellowish)
    By joecus in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-24-2012, 08:18 PM
  2. white-yellowish little dots on the side of the pool
    By cheharrison in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2012, 06:53 PM
  3. same old dirt
    By mja351 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2010, 12:17 AM
  4. Yellowish fittings-CL overdose???
    By otitis in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2006, 11:15 PM
  5. Thousands of yellowish [grey poupon] colored spots
    By jacthiele in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2006, 11:32 PM
