Thread: Rising pH??
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: Rising pH??
    My chlorine was 9.5 ppm this morning when the pH was well over 8. Yesterday morning my chlorine was 9.5 ppm and my pH was 7.6. I added nothing but maybe 1/4 gallon of chlorine last night. The same thing a few weeks ago....just a big spike in pH. It wasn't even a slow rise, just a big spike from one day to the next. I also tested a few times and from different areas of the pool just to make sure it wasn't a testing error and reading artificially high. Also there are no water features that would aerate my water, other than just the filter running which causes slight rippling in the surface of the water.
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    At some point this summer (there have been so many posts this season I can't begin to remember who the poster was) there was another post similar to this one, and the issue turned out to be residual indicator left in the test block. Are you careful to thoroughly rinse and dry your test block between tests?
    May or may not have anything to do with it, but it's the only suggestion I can think of at the moment....
