New user here. Been reading here a lot over the years and the forum has helped me alot. Looking for advice on replacing my pump motor now. I will post in equipment section.
Hi,
Until Ben completes your registration, this is the only forum you can post question in--but once he completes it, he'll move your post to the equipment section where it belongs.
Welcome to the forum!
What I have is a 2hp Hayward Northstar pump that will need a new motor. It seems oversized and is a energy hog. I can't find a variable speed motor that will work as a replacement but would like to get a 2 speed. I will probably keep my single speed timer and use a toggle switch for high when needed. Is there anything else I need to consider like flow to skimmers or priming on startup? just looking for advice or ideas, thanks.
What size is your pool?
16k gallon. I submitted my pool chart, did it not go through? Thanks
15x24 kidney 8K* gal AG concrete pool; Chlorine hand fed; Hayward pro grid cf48 DE filter; Hayward northstar 2hp 1 speed pump; 8 hrs; fountain or waterfall; Hth 5 way drops; well; summer: none; winter: none; ; PF:15
Note the correction in your gallons!
A 2 HP pump is way, way too big for your pool. You probably want something like this:
http://www.a1poolparts.com/-strse-84...eed/Detail.bok
You want the 1HP pump, and you'll want to leave it on low most of the time.
Sounds good, I am looking at just the motor replacement. I can get a AOSmith replacement 1hp 2speed with impeller for under $300 but cant find a variable speed bolt on that will work. BTW thats supposed to be a in ground on my pool chart. Many thanks.
On an 8,000 gallon pool, you'd be better off with a 2 speed pump. The variable speed pumps are all max HP motors, that can be turned down fairly efficiently. But, the 2 speed 1HP is going to as efficient, or more efficient than 2.5HP variable speed, turned way, way down . . . and it's going to be a heck of a lot cheaper and more reliable. Texas doesn't have the lightning Florida does, but putting electronics at the end of an power run outdoors is just asking for problems.
PoolDoc / Ben
Good point I've heard those vs control boards are expensive if you can get them. We can get zapped by lightning also. I'll get a 2speed. I think the skimmers will be ok with the lower flow at longer run times. Thanks again
