Results 1 to 8 of 8
Thread: Chlorine level good, but still green
    May 2011
    centralcalifornia
    Default Chlorine level good, but still green
    So, I get pool to shock ing level, clears up then maontain cl to above 3 but water still turns green within 3-4 days. This is even with out pool use ..temperature has been in upper 90 ' s to lower 100's. Pump running 12hrs a day and sand filter backwashed accordingly. Any ideas? Other than shocking, I maintain it to above 3 cl with tabs. The cya is between 40 and 45. No cc last time I checked. Pool is about 20k gallons but I round up to about 24k to be safe. Sand in filter is new. Dont brush as much as I should. But I thought the walls and floor would show that thier dirty, not the actual water. ThNks for any advice.
    Jul 2012
    Mexico, Missouri
    Default Re: Chlorine level good, but still green
    According to the best guess chart, 3 would be the bare minimum. You really should try to keep it closer to 5 or 6. That way you would have a bit of a buffer zone in case something tries to get started, as it seems to be trying to do. When you shock your pool, are you keeping it at shock level until you can go overnight without losing more than 1ppm? If not, then the algae tends to come right back, because you haven't killed all of it.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    May 2012
    Florida
    what charlie_R said!
    also are you checking that CYA yourself? you mentioned that you are using "tabs" to chlorinate. do they include stabilizer? if so that CYA could be higher than you think. i would double check/test those CYA numbers just to be certian. i would also shock to make sure you are getting rid of all that algae that keeps coming back, like charlie_R mentioned with out losing more than 1PPM of FC overnight, then dose as needed based off your CYA numbers.
    18' round 7.5K gal AG vinyl pool; bleach; waterway cartridge filter; waterway pump; 12hrs; taylor k-2005 and taylor k-1515a; utility water ; summer: none; winter: none; ; PF:16
    When you shock the pool to get rid of the algae, you have to keep it at shock level until ALL of the algae is dead, including what you can't see. If you don't, then it keeps coming back, as you've seen. Darkside and Charlie have brought up some good points--keeping the pool shocked until you're no longer losing chlorine at night is an important part of this process, but verifying that CYA level is probably a good idea.....
    When you brought the chlorine up to "shocking level", what level did you bring it to, and how did you measure it?
    May 2011
    centralcalifornia
    Sorry guys, been out for a while..makes sense..when I shock I bring it to 15ppm or more..the other day went up to 30. I use the taylor k 2006 and test my own cya of course. I use tabs and rea alize cya can go up but keep my eye on it's
    When I shock it I do it att night. I then run the filter 24/7 until water clears up. Usua lly over night already see a big dif
    differemce. but; I dont bother to check the chlorine afterwards, that is once I shock im pretty sure it will clear, but then greenish again within days. Never slimy and sticky walls or floor though. Th ere seems to be loose orange ish dust cludy deposits on floor but never slimy..thanks so much
    You're just not holding it at shock level long enough....you need to keep it there until you're not losing any chlorine overnight, then you can let it drift back down.
    May 2011
    centralcalifornia
    Ok, been kee ping shock level up since tuesday. Shocking att night , checking cl, then checkimg cl in the morning. First couple days it was losing about 7 to 8 then last c ouple days days about 4 to 5. last night raised to 18 and this ,m orning , att 10am with sun already out (previosly was checkimg @ 6:30 am) cl was att 16 ..my question now is if I been using liquid cl would I anticipate for cl to be lost att a higher rate than powder cl? The pool water is crytal clear right now and cl loss from last night was 2. The previois night was about same loss also. maybe im done? Thanks
    Ontario.
    Liquid or powder chlorine makes no difference. It's just chlorine when in the water. Sounds like you are pretty well there with the chlorine level holding.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. Cloudy green water, with a good Saturation Index
    By Anonymous European in the US in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2011, 03:12 PM
  4. my chlorine is good but water is green
    By river-wear in forum DPD-FAS based testing
    Last Post: 09-26-2006, 02:55 PM
