Re: What is ProTeam SupremePLUS?
I think the better comparison for the ProTeam Supreme PLUS product is boric acid since both are closer to being pH neutral. Boric acid is more expensive than the Borax and Muriatic Acid combination, but I find it more convenient. At The Chemistry Store, it's $1.85 per pound for a 15 pound pail. At poolgeek.com, ProTeam Supreme Plus is $3.67 per pound for a 10 pound bucket. One pound of boric acid provides the same borate level as 1.54 pounds of 20 Mule Team Borax with 11.83 fluid ounces of Muriatic Acid (31.45% Hydrochloric Acid). The Borax is $0.84 per pound from several sources so 1.54 pounds is $1.30 while the acid is $7 per gallon from several sources so 11.83 fluid ounces is $0.65 so the total is $1.95. So as in this example boric acid can actually be less expensive the Borax and acid, though I didn't factor in shipping costs which can be substantial (and you generally can't find boric acid in the stores for the online price the way you can with Borax and acid).
