Re: Phosphate battle
Thanks for the help, waterbear. I assume regular doses of muriatic acid are the best way to do this? I have been adding a pint or two in the morning and evening. Is there any danger of getting the PH too low before we hit the target TA range?
Does the use of trichlor tabs contribute to too high TA levels? If I stop using the chlorine feeder will I just have to add bleach every day?
21x45 rectangle 28K* gal IG vinyl pool; Chorine feeder; Hayward Pro Series sand filter; Hayward 1.5hp 1 speed pump; 8 hrs; ; 6 drops ; well; summer: none; winter: none; iPad; PF:4.2
