Thread: Pump HP for heater
    Western Pennsylvania
    Default Pump HP for heater
    I have my 24' AG piped into my outdoor furnace that puts out 225k BTU per hour. My question is my pump is a Hayward 1 HP (something) Flo and the hot water out of the returns is wimpy compared to when I'm not pumping into the heater. Would a higher hp pump be better or is this normal?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump HP for heater
    A heater increases the head loss experienced in your plumbing which in turns reduces flow so this is normal. However, many pools are plumbed so that water is not redirected around the heater when not in use as yours is so they do not notice any difference. I would stick with the 1 HP pump to minimize your power bill and just run it longer when the heater is in line.
    Mark
  1. Separate pump for heater?
    By DrMacZed in forum Intex-type Pool Setup & Operations
    Last Post: 07-27-2012, 02:01 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. Pump and Heater Piping
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 10:43 AM
  4. Gas heater vs heat pump
    By ElleM in forum Above-Ground Pool Construction & Repair
    Last Post: 03-05-2007, 05:10 PM
  5. Heater // when I shut off the pump...
    By sevver in forum Pool Equipment & Operations
    Last Post: 05-28-2006, 12:52 AM
