Re: Pump HP for heater
A heater increases the head loss experienced in your plumbing which in turns reduces flow so this is normal. However, many pools are plumbed so that water is not redirected around the heater when not in use as yours is so they do not notice any difference. I would stick with the 1 HP pump to minimize your power bill and just run it longer when the heater is in line.
