Thread: What is the easy way to know the builder of your pool
    rkrgk is offline Subscriber Thread Analyst rkrgk 0
    May 2012
    Phoenix, AZ
    Default What is the easy way to know the builder of your pool
    We recently bought a house which came with the pool. We dont know who built our pool. It is not possible to check with the previous owner as well. Is there any other way to get that information?
    Since I was having problem understanding certain details, even I dont know the size of the pool or the materials or the information regarding which valve is for what, I thought the best way would be to identify the builder and give them a call or request for some information or manual or that sort. Any ideas?
    Thanks for the help!
    18x32 kidney 15K gal IG Gunite pool; skimmer tabs; Hayward DE6000 DE filter; Hayward/AO Smith Superflow 1 speed pump; 12 hrs; heat pump, fountain or waterfall; Taylor K2006C ; utility water; summer: none; winter: none; android tablet; PF:8
    Default Re: What is the easy way to know the builder of your pool
    I don't know how you would get that information, unless maybe one of the neighbors was around when it was being built. If the previous owner was using a pool company to open/close or maintain the pool, they may be able to answer your questions if you can find out who it was. Maybe the realtor knows?
    Jul 2012
    Mexico, Missouri
    Most generally, there would have been permits pulled from your city/county authorities. You can check with them to find the builder. These are public records that you as the owner of the house would have access to. You will find a LOT of info on your property at the county courthouse.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    May 2012
    Phoenix, AZ
    Thanks Charlie_R, Aylad.
    I guess I should give a call or pay a visit to the county court!
