Results 11 to 12 of 12
Thread: what order to add the chemicals
    Jul 2012
    Mexico, Missouri
    Default Re: what order to add the chemicals
    I was just thinking that the water volume difference would have bearing on it, that's all.
    Thank you, Watermom!
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Quote Originally Posted by alisonquilts View Post
    The only reason I am so curious is that I am sure I read a thread which mentioned a couple of chemicals that would precipitate if you added them too close together
    That's when you add calcium PLUS either sodium bicarbonate (Alk Increaser) or sodium carbonate (pH Increaser) at the same time. You have a vinyl pool, so you NEVER need to add calcium. (Problem solved!)
  1. Order of adding chemicals - question
    By rannrich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2012, 07:26 PM
  2. Before I order is this the right Kit.
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-18-2008, 05:47 PM
  3. Any particular order for new pool?
    By DONNIE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-30-2006, 05:31 PM
  4. Alk/PH Which order?
    By cav in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2006, 05:38 PM
