Thread: pump leak
    Aug 2010
    Default pump leak
    Hello,
    I have a duraglas pump that I have gone through about 4 or 5 motors with in 6 years. I just installed another new one yesterday. I always have a leak problem, though I always install new seals. I have watched multiple youtube videos and looked up various pump manuals (including my own) to ensure I am installing it the right way. It leaks between the motor itself and the back plastic housing. Could it be anything at all besides the seal? I have verified on http://www.ussealmfg.com/ that it's the correct one for my pump with the part number from the manual. from this image the leak is behind part #5 and in front of part #4.
    http://cf.mp-cdn.net/56/45/1c45e5187...1e264b3fa1.jpg
    it does not leak when the motor is off, and the water stays full in the pump basket area.
    Thanks.
    Default Re: pump leak
    Sounds like the impeller shaft seal to me...when you replace the seal, does it stop leaking at all, even for a short amount of time?
    Welcome to the forum!
    Aug 2010
    Hello,
    I just put a new one in the with new motor yesterday and there is no change whatsoever. the old one was less than a week old too. it fits in so well I can't understand how it could possibly be leaking.
    I dunno--but there are others on the forum that probably will. However, traffic is falling off at the forum right now, so it may take a few days before folks check in again. I'll ask Pooldoc to check in here and see if he can offer you any suggestions.
    Aug 2010
    Praise the Lord I finally found the problem. there was actually a crack in the seal plate itself. I was able to block it off and no more leaking.
    Jul 2012
    Mexico, Missouri
    A question for you, Reebok.
    In that exploded view you linked, it appears that callouts #4 and #8 both would be contacting #5. Am I right? If that is true, then you probably need to look VERY closely at the area where they would be touching #5. If there is even the slightest deformation there, you would get a slow leak.
    As I don't have experience with pool pumps, I am going by my experience with industrial and automotive equipment.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
  1. Pump leak
    By chumpy36 in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2011, 05:24 AM
  2. leak under pump
    By tggs in forum Pool Equipment & Operations
    Last Post: 04-15-2010, 04:40 AM
  3. Pump leak?
    By Bnelson in forum Pool Equipment & Operations
    Last Post: 05-26-2009, 03:20 PM
  4. leak in new pump?
    By Garvacious in forum Pool Equipment & Operations
    Last Post: 03-26-2009, 08:12 PM
  5. Pump Leak
    By rilesworld in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2007, 07:36 PM
