Thread: Do tri-chlor tabs lose potency?
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Default Do tri-chlor tabs lose potency?
    I have an opportunity to get a pretty good price on 50 lbs of 3" tri-chlor hockey pucks. This is probably a little more than I use in a season. I'm about to close my pool and will use this next year. Will this chlorine lose any of it's potency over the winter? If so, will it lose enough to really matter? It will be stored in a shed in the yard. I hate to pass up a good deal like this, but I don't want to end up with ineffective chemicals.
    Thanks,
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    Default Re: Do tri-chlor tabs lose potency?
    Just check the ingredient label before you buy them and make sure that they don't contain copper!
    New York
    Thanks guys.
    Tom
  1. Why Does My DE Filter Lose Pressure
    By AnnaE in forum Pool Equipment & Operations
    Last Post: 05-26-2015, 05:50 PM
  2. chlor.tabs with cya?
    By fhorta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2011, 03:44 PM
  3. How many PPM of Chlorine should I lose daily?
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 06:06 PM
  4. Suction Leak Causes Pump to Lose Prime
    By donjoarm in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 12:00 PM
