Results 1 to 3 of 3
Thread: FAQs & HOWTOs: Swimming Pool Alkalinity
    Exclamation FAQs & HOWTOs: Swimming Pool Alkalinity
    HOWTO: Step-by-Step Guide to lowering your alkalinity
    The HOW-TO has moved here: lowering-swimming-pool-alkalinity-step-by-step.html
    You should also read the Muriatic acid guide, here: http://www.poolforum.com/pf2/showthread.php/29112
    FAQ: Questions about Alkalinity
    The FAQ and other alkalinity pages are found here:
    total-alkalinity-in-swimming-pools.html
    Lowering Calcium Hardness via "Lime Softening"
    Default Re: HOWTO: Lowering Your Alkalinity
    Do you simultaneously aerate and apply muriatic acid? Some people say to let the acid sit for up to 12 hours and you say to turn the pump on and aerate. Please clarify.
    Thanks,
    Kenny
    It doesn't really matter.
    The aeration won't begin to have much effect till the pH is lowered, but it won't hurt anything, either.
    Ben
  1. PoolForum Guides & FAQs
    By PoolDoc in forum Forum Q & A
    Last Post: 06-12-2018, 02:31 PM
  2. FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders
    By PoolDoc in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-03-2018, 08:55 AM
  3. FAQs & Guides: Intex-type Pool
    By PoolDoc in forum Intex-type Pool Setup & Operations
    Last Post: 06-01-2018, 03:22 PM
  4. FAQs & Guides: Testing & Adjusting Pool Chemistry
    By PoolDoc in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2018, 04:51 PM
  5. FAQs & Guides: Above-ground pools
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 11:57 PM
