Re: Pressure issues Sand Filter
I am assuming that your pool is an above ground. You might be able to install a larger inlet eye ball the one you have could be to small for the amount of flow that you have. The Polaris 65 has a pressure relief valve on it so you can reduce the flow to it. If you have the larger type eye ball inlet and you still have to much flow then just add another return to the pool so you do not have so much flow coming out of one return. I would not add DE to the filter unless you have a water quality problem and if you do have a water quality issue then check your chemistry first.
