Re: Pool closing special conditions
membership updated; thread moved. -ben
An alternative to messing with the cover and such, is to put either heavy oil or detergent in the pool. A little oil, or a lot of detergent, will prevent mosquito larvae from surviving.
Of course, you have to think about where the mess will go, when you pump the pool. The oil shouldn't be an issue, unless you over do it; the detergent might be, depending.
