Results 11 to 14 of 14
Thread: Replacing Seals on pump; original or aftermarket parts?
    Virginia
    Default Re: Replacing Seals on pump; original or aftermarket parts?
    It's not suppose to rain today so when I get home this evening I should be able to tell if there are any more leaks.
    Virginia
    The equipment pad is dry!
    The pump isn't leaking and the PVC repair (another thread) is holding.
    great! bet you feel good about it that you did it yourself!
    Virginia
    Yes it does. Feels even better I saved a bunch of money.
  1. Need new pump. Buy seals too? Quick response needed!
    By JimK in forum Pool Equipment & Operations
    Last Post: 03-10-2017, 10:33 PM
  2. Pump seals and salt based chlorine generator
    By BrianM in forum Pool Equipment & Operations
    Last Post: 06-05-2012, 03:55 PM
  3. Intex pump replacement looks different than original
    By GreatCanadian in forum Above-Ground Pool Construction & Repair
    Last Post: 11-08-2011, 09:33 PM
  4. no pump pressure even with all new parts
    By atv250rman in forum Pool Equipment & Operations
    Last Post: 06-05-2011, 04:42 PM
  5. Pump parts online...
    By RocKKer in forum In-Ground Pool Construction and Repair
    Last Post: 01-31-2007, 02:04 AM
