Results 1 to 10 of 14
Thread: Replacing Seals on pump; original or aftermarket parts?
    Virginia
    Default Re: Replacing Seals on pump; original or aftermarket parts?
    I replaced the seals today without much trouble and so far the pump doesn't seem to be leaking, at least not as much as before. It's hard to tell since it has been raining today. I'll be able to tell better once the concrete pad it sits on dries out.
    I'm not sure if this is because these seals are aftermarket parts, but the housing gasket and the strainer basket gasket were a little too large. I did manage to seat them properly after fussing with them a bit. The other seals seem to fit perfectly.
    Thanks Waterbear, I greatly appreciate your help.
    The gasket and o rings often have to be worked into place whether OEM or aftemarket and the Aladdin parts such as the Go kits are pretty good quality and widely used. The only part of the theirs that I am not crazy about are some of their skimmer baskets.
    Virginia
    It's not suppose to rain today so when I get home this evening I should be able to tell if there are any more leaks.
    Virginia
    The equipment pad is dry!
    The pump isn't leaking and the PVC repair (another thread) is holding.
    great! bet you feel good about it that you did it yourself!
    Virginia
    Yes it does. Feels even better I saved a bunch of money.
