Results 1 to 9 of 9
Thread: got complacent green now
    May 2012
    Iowa
    Default got complacent green now
    I was doing great. Adding liquide bleach. Shocking once a week. Test results at the pool store dead on. Water crystell clear. then a cold spell, increased workload Wa wa I know.
    Bottom line is I am green.
    24'x52" AG
    approx 14645 gal
    Liquid bleach daily
    Liquid shock weekly
    Muratic when PH gets high.
    Current test results
    3.6 fc
    .2 cc
    60 TA
    120 Calc Carb
    60 CYA
    Last actions
    Added a little less than a half gal Muratic
    Currently adding boxes of Borax (I bought 4)
    Keep on keeping on? Or am I screwing the pouch?
    thanks in advance
    bssage
    Default Re: got complacent green now
    You don't list a pH level, so I can't advise you on that--but it seems odd to me that you've added muriatic and now you are adding Borax? What is the current level?
    To clear up your pool you're going to need to run your chlorine up to 20 ppm and hold it there until the pool clears up and until you can go from sundown one night to sunup the next morning without losing any chlorine.
    May 2012
    Iowa
    PH 7.2
    I saw that I had left that out. But my post had to go through the mod before I could edit.
    I began with the muratic because I had used that in the past to bring the PH down. And a side effect seemed to be that it also cleared the pool (it was just dull at the time). A few days ago my ph was high (top of the test kit.) and the pool green. So I figured "two birds, one stone"
    My brain was saying high ph = chlorine not working=green pool. So my brain said +muratic = good ph + Chlorine= clear pool.
    If it's still green, you need to think chlorine + chlorine + chlorine = clear pool.
    May 2012
    Iowa
    OK I am at a translucent aqua now.
    Just finished vacuuming and cleaning strainers (skimmer/pump) Keep dosing with liquid chlorine until clear??
    PH low 6.5 (brought it back down before last dose 6 gal)
    FC high 22
    CC difficult to measure extremely light and cleared up just looking at the reagent.
    Quote Originally Posted by bssage View Post
    FC high 22
    Not till clear; till NOT-green, even after brushing. Clearing up the dead algae is a job for your filter or vacuum, not chlorine. But you have to kill it first.
    Don't worry about CC levels; with algae in the pool, they may fluctuate some. Just concentrate on the FC levels, until all the algae is long gone.
    May 2012
    Iowa
    will leaving the solar cover hurt? Evenings are getting cold. If I can I want to salvage whatever heat for when it clears?
    And thanks I know you all are on your own dime helping out. I appreciate it.
    Leave the pool at least partially uncovered; when chlorine is cleaning up a mess, chlorinated byproducts form and are released. The BEST way to get rid of them is to let them gas off, and be destroyed by sunlight. But they can only do that if the gasses are not trapped by a vapor proof cover.
    In fact, leaving a cover fully in place during clean up, can damage the cover! Happens on spas regularly.
    May 2012
    Iowa
    Junk headed out now.
    thanks
    24 round 12.9K* gal AG vinyl pool; liquide chlorine; sand filter; 2 1 speed pump; 8 hrs; ; the recommended Taylor kit; utility water; summer: solar; winter: mesh; android phone; PF:9.3
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
