during the time isaac blew through the carribbean and gulf of mexico we were getting a lot of on and off heavy rains. on monday 8/27/12 we had a heavy rain band that stayed over our area for several hours causing a lot of flooding. i must have drained 1ft of water of my pool in just a couple of days.
due to all the rain there was a couple days that i was unable to test FC as i felt i would not get accurate numbers as the water was being diluted constantly by steady rain. i did however bump up my FC ( before teh storm ) and added 2-3 quarts of bleach a day to help deal with all the rain.
well the rains stopped and i was finally able to test ( in my garage late on 8/27 ) after adding 1.4 gal of bleach a few hours before. i measured 20ppm FC so im guessing i was right around 8ppm FC before adding the 1.4 gal.... im not supposed to go below 8 with my CYA of 110/120... so i just bumped my FC up and thought every thing was peachy!
because of all the flooding i was getting home after dark due to an increase in my work load, so on 9-1-12 i was finally able to run a full set of test's. here are the numbers.
FC - 9ppm ( i expected more FC )
CC - 0 ( i always get a CC of 0 )
PH - 7.6 ( been holding 7.6 all sumer )
TA - 90/100 ( was at 120 most of the summer and holding )
CYA - 90/100 ( was running 110/120 all summer and i like it like that! )
the last few days of testing ive seen in increase in FC loss. i tested on 9-1-12 in the evening at 7:45 pm ( sun was off the pool ) and measured again on 9-2-12 in the morning at 7:30am ( before sun was on the pool ) and lost 2.5ppm overnight. im used to losing only 2-3ppm in 24 hours!
this evening i measured a trace of CC but there was no CC during this whole isaac thing. i did vacume out a bunch of leaves, bugs, pine needles, etc yesterday...i didnt see any visable algae during vacuming as i use a mask and snorkle so i can see what im doing.
i tested FC tonight ( and got the trace of CC ) so im gonna measure again in the morning. if i lose more than 1ppm of FC im going to start the shocking process up to 25ppm. im also going to drop a couple of triclor pucks in the floatie to get back some CYA....
i dont think the FC lose if from the drop in CYA/UV but im no expert! any other thoughts or ideas? the pool is crystal clear by the way.
