Thread: Lots of algae, 0.5 CC
    Default Re: Lots of algae, 0.5 CC
    Elevated CC levels are normal ANY time you have something using up a lot of your chlorine -- algae, pee, pool party, swim lotion, yellow algae 'treatments', etc.
    Eradicate the algae, and then see if you still have elevated CC levels, but don't worry about them right now.
    Jul 2012
    NJ USA
    Do you consider .5 elevated. This is the level I've had all summer and the water was clear, why didn't the level go up when I had algae.
    Thanks.
    18x34 oval 16K gal AG vinyl pool; tabs; Hayward sand filter; Hayward 1 speed pump; 8 hrs; Taylor K-2006; utility water; summer: none; winter: vinyl / water bags; iPhone; PF:7.5
    I simply assumed that 0.5 was higher, since you asked about it.
    But, if you test with the K2006 using a 10ml sample, then it's not uncommon to see some pink, which disappears with the first drop of FAS, giving a 0.5 ppm reading. My guess is, if you test with a 25 ml sample, so 1 drop of FAS = 0.2 ppm FC, instead of 0.5 ppm, you'll then see a CC level of 0.2 ppm.
    If your pool is lightly used, your filter sand is clean, and you use only basic chemicals . . . you may see a 0.0 reading even with a 10 ml sample.
    However, if your pool is fine otherwise, and you only see a 'first drop' CC reading . . . I don't think you need to be concerned.
    Quote Originally Posted by zoffPool View Post
    CC (combined chloramines) are formed when the chlorine is fighting something, like algae, in the water. They are eliminated by chlorine that finishes the job, and are also eliminated by burning off via sunlight. I've had algae blooms, bad ones that happened while my pump was out of commission, in my pool before and still had 0 CC, which is why I don't consider it a reliable sign of algae growth.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. Pool is brown...tried lots of things...lots of problems!
    By ravencr in forum Commercial Pool Users, Managers & Workers
    Last Post: 06-24-2011, 01:37 PM
  3. Lots of questions...
    By melanieholloway in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2011, 06:38 PM
  4. Lots of drops, can I do this?
    By steveinaz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-20-2007, 01:41 PM
  5. Using Lots of Bleach
    By Jaybird70 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-20-2006, 12:01 PM
