Results 1 to 10 of 14
Thread: dichlor (a sunlight stabilized form of chlorine)
    Ontario.
    Default Re: dichlor (a sunlight stabilized form of chlorine)
    When buying bleach, check the strength of the bleach carefully. I haven't found any generic brand 6%. Walmart's is 4% and a lot of other stores don't tell you the strength and it is usually as low as 3%. You may find some Clorox in 6% strength.
    If they still have it in stock, you can 12% liquid pool chlorine (bleach by another name), at CTC - the Aquaris brand is $4.69 for 5 litres, which is about 1.3 US gallons. As I learned here, if you don't use the 12% right away, keep it in a cool place as at 80 degrees+ it will lose strength very quickly... not a issue this weekend anyway.
    The pucks sold at CTC, Walmart, or pool stores like Campbell or Mermaid all have stablizer in them. "stabilized chlorine" is not any different than bleach or other methods of delivering chlorine. It just means that they had included stabilizer (CYA) with the chlorine.
    You can buy stabilizer (CYA) by itself, so you can bring up the stabilizer level and use regular bleach.
    Stabilizer will break down over winter, so with the weather, and that we are pretty well at the end of the season, there likely isn't a big advantage in adding a lot now.
    Ton of rain today, at least 2 inches. Had to drain the pool as the water level was above the skimmer.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Sep 2012
    Ottawa, Canada
    Hi if I get the 4% one do I just put more in the pool or do I need the 6%?
    Thx
    18 oval 7K gal Intex-type AG vinyl pool; splash time, a+c cartridge filter; sfs2000 210watts 2.2amps 2000g.p.h pump; 8 hrs; 1. aquarius, test strips just got aquarius, trousse d'analyse dual test kit; well; summer: solar; winter: none; iPhone; PF:17
    4% is fine; just add 1.5x as much.
    Is 4% the more common strength in Canada?
    Ontario.
    3-4% is common for the supposedly cheaper store branded bleach. 5.25% is common for name brands like Javex or Clorox, but the cost is quite a bit more. Sometimes you can find 6% Clorox.
    Walmart used to carry 6% in its generic brand, like in the US, but changed that to 4% last year while leaving the price the same. All the store brands that I have checked are 3% to 4%, which doesn't end up as much of a saving.
    Just to edit - this is for my location and seems to hold for Ontario in the east. It may be different in Western Canada as there can be significant differences in what is available.
    That's why I have steered Canuck posters to the 12% at Canadian Tire. 5 litres sells for $4.69 vs. $8.99 at the pool store.
    I gather that Canadian Tire is a multi-line distributor with many outlets in eastern Canada?
    Sep 2012
    Ottawa, Canada
    ya its like a Walmart, just a guys Walmart, lol
    pool is looking better today thx just put 2 more gallons in it
    Quote Originally Posted by Gibby View Post
    I'll try to remember to poke around their website a bit next spring, to see what pool stuff they have. I assume they have relatively good prices?
    Ontario.
    It is a coast to coast chain with 487 retail stores that first opened in 1922 and 90% of Canadians are supposed to live within a 15 minute drive of one. Multi-line centered around automotive, housewares, diy, seasonal and recreation. Some stores carry a bit of groceries.
    http://www.canadiantire.ca/home.jsp?locale=en
  1. Chlorine stabilized, pool not green, what's next.
    By keastman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-09-2012, 07:08 PM
  2. Does pH change when covered/with lack of sunlight?
    By elsie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-27-2010, 04:30 PM
  3. non stabilized chlorine
    By nisqu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2008, 07:03 PM
  4. Replies: 13
    Last Post: 06-08-2008, 09:03 PM
  5. HTH Non-stabilized chlorine tablets
    By vanhout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2006, 10:42 AM
