Thread: Jandy deck jets
    VA, USA.
    Default Jandy deck jets
    Does anybody have any experience with Jandy deck jets? I’m planning of adding water features to my pool. I had the plumbing placed into the deck when we build the pool. Now I would like to add deck jets and the only one I found so far are the Jandy deck jets.
    http://www.jandy.com/html/products/w...s/deckjets.php
    Cheers Guido
    Default
    I have the Polaris mini deck jets in my pool. Fiberstars makes fiber optic lighted jets but if you havent run the pipes for the fiber optics you probably can't use them. Also they are expensive!
    VA, USA.
    Default how about installation?
    Hi waterbear, was this a big hassle to get the jets installed? Is that something you would consider doing yourself?
    Guido
    Default
    I had my builder install them since I am lazy but I did read the intall manual and it didn't look too hard for a competent do it yourselfer. The manual can be downloaded from the Polaris website so you might want to take a look.
    http://www.polarispool.com/home.htm
    Waterworks is offline In the pool biz Thread Analyst Waterworks 0
    Default
    The installation of polaris or jandy deck jets is really very simple. If you're at all experienced with pvc or plumbing and you read the installation manual, you will no problems at all.
    Brad
  1. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. Deck Jets on existing pool
    By newpoolguy in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2011, 04:21 PM
  4. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
