Thread: Pool is green, wanting information on BBB practice :)
    Sep 2012
    Default Pool is green, wanting information on BBB practice :)
    Our 18' x 36' inground pool is green. I don't want to close it yet, even though it is too cold to swim. It went green after we had a big rain and a financial decline at the same time.... When it rains........... So I am trying to find out more about the less expensive route of degreening with BBB. Any assistance would be greatly appreciated.
    Default Re: Pool is green, wanting information on BBB practice :)
    Probably the cheapest way is simply to dump bleach in, till you get an OTO orange level.
    That's a guess: to do more than guess, we'd need good test results, and for that you'd need a good test kit. I don't know if that fits your budget or not. On the chance that it does, I've put some test kit info below.
    Ben
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE, but is an ESSENTIAL tool for pools with problems. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
  1. Starting up pool and wanting to convert from baquacil to BBB method ?
    By waterbreak in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-07-2012, 03:06 PM
  2. New pool owner wanting to convert to salt chlorination system
    By dayna78 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-01-2012, 06:26 PM
  3. Wanting a new pool.
    By Joplin_MO in forum In-Ground Pool Construction and Repair
    Last Post: 09-10-2007, 01:37 PM
  4. Wanting to plumb a dedicated vacuum port in my IG pool. Need advice...
    By Socal_biker in forum In-Ground Pool Construction and Repair
    Last Post: 08-05-2006, 01:14 AM
  5. useful sites for pool information
    By LBD in forum General Interest
    Last Post: 04-23-2006, 11:41 PM
