Thread: replace or repair damaged pump motor
    May 2012
    Phoenix, AZ
    Default replace or repair damaged pump motor
    My Hayward (A.O. Smith) pump motor fail due to my stupidity. Too much debris in the pump strainer.
    I opened the back, and could see the plastic case for the capacitor is melted. Is it worth trying to have it repaired, or attempting to replace the capacitor? Or should I just buy a new motor?
    It's a single-speed 2HP motor, about 7 years old.
    Thanks,
    hikernut
    Default Re: replace or repair damaged pump motor
    Poconos is good on motors.
    Hikernut,
    Have you resolved the problem? If not, I can shoot Poconos an email and have him check in here to give you some advice--he's the best one around when it comes to motor repair...
    mas985's Avatar
    Pleasanton, CA
    Replacing the capacitor is fairly easy and cheap to do so I would try that before scraping the motor.
    Mark
