Results 1 to 10 of 15
Thread: Do Acid Feeders exist for salt water pools
    Sep 2012
    South Texas
    Cool Do Acid Feeders exist for salt water pools
    Is there any type of Acid (pH minus) feeders that can be used with chlorine generators in salt water pools to keep the pH near where it should be. I was thinking something like the in-line or floating chlorine feeder style. Just something to add nearly the right amount of acid to keep the pool near balance until it could be checked. Like to use while on vacation or all the time for that matter. The pool installer was offering me this multi $1000 dollar electronic contraption to control the chlorine and pH but that is not what I am looking for. I just want something simple and cheap to dribble a little acid in all the time that could be adjusted as needed to find the sweet spot.
    Largo, Florida
    Default Re: Do Acid Feeders exist for salt water pools
    They exist, but as you noticed are a little pricey. Not to mention if you have one and it fails and brings the pH too low, it could seriously damage your pool. There are some other options; watermom has written up a detailed post on some ways to minimize pH rise in swcg pools: http://www.poolforum.com/pf2/showthr...-in-SWCG-pools
    Item #6 had a big impact for me, and the instructions for how to do it safely can be found here: http://www.poolforum.com/pf2/showthr...stant-to-Algae
    In my case I found I can go about twice as long between doses of muriatic with the borax; although I have to add twice as much when I do. Since it inhibits algae growth you may be able to get away with slightly lower output on your swcg as well (which will in turn reduce aeration that causes pH rise).
    One more thing not mentioned in watermom's post. If you have any water features such as a waterfall, or even have the return eyes pointed so they are rifling the surface of the water - those will cause the pH to rise faster. Turn the eyes downward, and turn the water features off - both will help you.
    I asked about one of the systems you reference just over a year ago. Check out the responses about the systems for more details: http://www.poolforum.com/pf2/showthr...e-amp-Dispense
    Sep 2012
    South Texas
    Can a chemical acid metering pump (proportional type) be used that is connected to the same power source signal that controls the Chlorine Generator cell unit? This way at least a little acid will be entering the pool while the unit is generating chlorine. I guess one would also need to know the estimated size of the acid metering pump required in some units (gallons per day, oz/hr, oz/day)? Anybody have an estimate of how much acid they put in the pool per day, week etc. per 10,000 pool size or some similar units as a starting point. I would also need to know the estimated time the cell was in operating.
    Virginia
    Quote Originally Posted by kelemvor View Post
    They exist, but as you noticed are a little pricey. Not to mention if you have one and it fails and brings the pH too low, it could seriously damage your pool. There are some other options; watermom has written up a detailed post on some ways to minimize pH rise in swcg pools: http://www.poolforum.com/pf2/showthr...-in-SWCG-pools.........
    I pretty much folllow that advice, except my TA has been 90-100 and my borates at about 60. My pool seems to have stabilized at about 7.6 and I haven't had to add acid since the middle of June.
    Sep 2012
    South Texas
    In that case then it probably won't be a big deal. I had thought that Acid needed to be added every day.
    Largo, Florida
    I end up needing a dose about every two or three weeks.
    Virginia
    I use to add acid when the pH hit 7.6. At that time I was adding acid every week. Following the advice here about TA/borates and not worrying about adjusting until pH rose above 7.8 made a big difference as I noted above.
    Virginia
    Quote Originally Posted by mnittler View Post
    Thank goodness there's nothing I have to add every day! (Well, technically chlorine, but the SWCG takes care of that )
  1. Muriatic Acid in small pools?
    By scornn in forum Dealing with Alkalinity and Calcium
    Last Post: 06-20-2012, 08:21 PM
  2. Intex Salt Water System for Larger Pools?
    By poolguy123 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2011, 07:09 PM
  3. Need advice on Dichlor vs. salt water feeders
    By Luvtlee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2006, 10:32 PM
  4. Salt water ok for Rock Pools ?
    By JohnInSoCal in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2006, 08:42 PM
  5. Why is sulfuric acid not so good for plaster pools?
    By smallpooldad in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2006, 08:34 PM
