Thread: Pump loosing suction
    Sep 2012
    Middle Tennessee
    Default Re: Pump loosing suction
    Thanks mas985. I tried that using an expandable bladder. After pushing water from both ends of the line I was able to force some debris out of the line. Thats one of the major reasons I concluded that there must be something in there catching and holding stuff.
    Thanks for doing a little head scratching for me on this. Any other thoughts please let me know.
    BTW, you can get expandable bladders that screw on the end of a garden hose in different sizes. Works fairly well on some clogs around the house and is chem free! I got mine at Lowe's but most any hardware store will probably have them.
    Thanks again
    20x40 rectangle 36K* gal IG painted concrete pool; Chlorinator; Tagelus sand filter; Century Centurion 1 speed pump; 8 hrs; solar heat, Solar Heater home made; Taylor K-2006; utility water; summer: none; winter: mesh; android phone; PF:4.4
    mas985's Avatar
    Pleasanton, CA
    I have done it both ways but I find that a straight hose can get more force into the pipe so you might want to try it that way too.
    Mark
    Sep 2012
    Middle Tennessee
    That was the first way we tried and honestly there just wasn't enough 'push' to move things along. Thats what led to using the expandable bladder. It will hold water, thereby increasing pressure, until the bladder expands to fill the inside diameter of the pipe. Once reached, the water is forced out the bladder. It's a dedicated vacuum line that was added sometime after the original construction.
    Thanks again for your input and for taking time to help us figure it out
    doc
  1. Loosing suction
    By Hardley8 in forum Pool Equipment & Operations
    Last Post: 08-01-2012, 01:35 AM
  2. Loosing Prime
    By Miguel in forum Pool Equipment & Operations
    Last Post: 04-30-2012, 02:01 PM
  3. Loosing too much chlorine overnight
    By douge55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2011, 08:51 AM
  4. Pump has suction hose does not
    By Slatershere in forum Pool Equipment & Operations
    Last Post: 09-24-2010, 06:47 PM
  5. No suction from pump
    By butlercns in forum Pool Equipment & Operations
    Last Post: 08-04-2006, 11:35 AM
