Re: Metal Stains ?
Stains are light brown in color more like a light rust . Taylor 2006 Kit . He measured today and FC was 4 CC was 0 CYA was 50 ph 7.4 alk 80 hardness 180. He has enough of ascorbic acid to go around pool and it appears stains are gone. Will open today and take a better look as weather has been cold. No did not add a sequestrant. As for heater it is a Laars 2 Lite Teleydyne and not 100% sure but says it has a cermaic heater core but not sure my model which is 10 years old does .Need to check when home on Wed . He did clean off the solar cover and got the leaves off . It appears the absorbic acid brought the PH down a little .
16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
Been on bleach since 2012
