Results 11 to 17 of 17
Thread: Need MORE info than STICKY has PLEASE on closing AGpool
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Default Re: Need MORE info than STICKY has PLEASE on closing AGpool
    Ok guys I think I'm set in my mind what to do when I finally do it!! Will shock and use polyquat but wont run filter once polyquat in..right?..Have my son or DH put plate on so can leave level up like Brothers 3 suggested. Hayward DE filter apparently came with return plug with inside pool which we will remove eyeball and install. Have them..tie pillow to middle, put on winter cover and use wind guard 5" cover clips all around. I guess filter needs to be drained, the cloth in it cleaned, hoses disassembled. Will keep tank in garage and perhaps motor in house. I will have the 'men' check values and do all that mechanical stuff...lol...And I should be fine!!! Oh also buying a submersible cover pump...
    BUT like you said Dave, if I open to green, I do know what to do!!!
    THANKS
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    Why wouldn't you run the filter after you add the polyquat? I do.
    Jun 2012
    Long Island, NY
    OH I thought I read here somewhere that you shouldn't??????????????Would filter it out????
    OK then I can, I guess...easier
    You should put the filter or recirculate after the polyquat is added or it will be filtered out.
    Jun 2012
    Long Island, NY
    I didn't know my filter has a recirculate mode..I will check it out...Thanks
  6. #16
    Aug 2012
    Michigan
    We have a rectangular AG vinyl pool also. This is our first year to close. My husband wants to use a vinyl tarp to cover it, will this work? We can't find a rectangular pool cover. What is the mesh cover you are using and where did you get it? Also, do you have a skimmer? We don't but we sure do need one. Could we install one? Thanks so much.
    12x22 rectangle 5.9 gal AG vinyl pool; tabs in a floater; sand filter; pump; 4hrs; Test strips with 6 tests, well; summer: none; winter: vinyl / water bags; none; PF:20
  7. #17
    Grammy, you'll have more luck getting answers to your questions if you will start a new thread with your questions rather than tack onto the end of this one, which isn't likely to get many more views....
    I don't have any answers to your questions, because my climate doesn't require closing the pool, and mine is not covered...but hopefully somebody else will be able to offer you some good advice.
  1. Question about the Borax sticky note.
    By St8kout in forum Dealing with Algae & Slime
    Last Post: 07-04-2013, 11:08 AM
  2. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  3. Suggested Sticky Topic
    By jhm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2010, 09:54 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
