Thread: AGP Filter
    Aug 2012
    Wisconsin
    Default AGP Filter
    My 24' AGP will not stay clean. My pool guy says my 100# Waterway sand filter is not adequate and a low-end alternative. What would would you guys feel is the best filter system option? Thank you
    Default Re: AGP Filter
    A lot depends on what size pump you have--if the pump is oversized for the filter, then it just pushes debris through the sand and back into the pool. If you can list what size/HP pump you have, it will be easier for the equipment folks to give you a better answer...
    Aug 2012
    Wisconsin
    I know my motor is 3/4HP...is there anything else you need to know? Thank you!
  1. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 07:54 AM
  2. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  3. Help! Switching out 1985 cart filter to sand filter
    By JLICHTY in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 11:09 AM
  4. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  5. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
