Hi, My water tested and results are as follows......
total chlorine 34.0 ppm
ph 7.2
hardness 150
alkalinity 200
cynaruic acid 15
My pool is still cloudy and I TRIED to vacumn to waste but my hose kept coming out of the suction thing in the skimmer. I cleaned some of my pool, as I cant see the bottom and I did it to filter then backwashed it. I left my pump off, again, to settle the algae? to the bottom of my pool. I had put in 80 litres of chlorine sat then formula 500 algaeside and then ph stuff < dont know what the name is anymore. My pool is cold as my heater doesnt work, but I do not have my solar cove on.
I bought a two way water test today and will test my water in the morning, along with bringing a sample to the pool store. I cannot get borax here, but we have regualr javex, which is the same.
What can I do now to get my pool working??
