Results 1 to 10 of 12
Thread: First post - Trouble maintaining Chlorine
    Tucson, AZ
    Default First post - Trouble maintaining Chlorine
    Lastest water test at local pool store:
    CYA 168
    TC 0.6
    FC 0.6
    pH 6.9
    TA 126
    TH 527
    TDS 2100
    20,000 gal, in-ground gunite
    Cartridge filter
    We are having to shock every week. We are currently stuck in that "Bioguard is the best" trap. We use the Smart Sticks in our skimmer and the Bioguard shock products.
    Tucson, AZ
    In-ground Gunite
    20,000g
    Default Re: First post - Trouble maintaining Chlorine
    Quote Originally Posted by ubalr1
    CYA 168
    TC 0.6
    FC 0.6
    pH 6.9
    TA 126
    TH 527
    TDS 2100
    Cartridge filter
    Ubalr, welcome ot the forum! Your numbers are certainly from a pool store, honest folks who do their own testing get numbers that end with "0". Your cya and hardness results make a partial draining a good idea, but only if the fill water is lower in calcium. My best advice is to get a good test kit and learn how to use it, take control of your pool. Your pH is way low, dump a box of Borax in ASAP, and a couple gallons of regular (unscented) bleach in the pool -NOW (with your cya so high, you need a lot of chlorine) I'm sure that others who know more about the chemistry side will post, but do what I'v said as soon as you can. Good luck with the pool, you can escape the Biocrud cycle if you take matters into your own hands.
    Tucson, AZ
    Quote Originally Posted by waste
    Thanks Waste. Not sure I understand this "honest folks who do their own testing get numbers that end with "0"." We do have our own tester that we use on a sporadic basis. Our numbers are in the ballpark with the pool store. We just added 12lbs of sodium hydrogen carbonate (aka., soda ash, baking soda, sodium bicarbonate). We'll see what that does. The water in my area is very hard (19-20 grains, ?ppm). So, I am thinking of switching the auto-fill supply from hard water to soft water. I should have done it summer before last when we drained the pool. Still considering (researching) the whole liquid bleach approach.
    Tucson, AZ
    In-ground Gunite
    20,000g
    Tucson, AZ
    BTW, from what I find online, Borax and soda ash are not the same thing. Does Borax (also called sodium borate or sodium tetraborate) do the same thing chemically in the pool as Soda Ash (also known as sodium carbonate, sodium bicarbonate, sodium hydrogen carbonate)?
    Never mind. I'm learning as fast as I can - the more I read through this forum. Add Borax to raise pH. Add soda ash to raise total alkalinity. Both problems (low TA and low pH) that I have according to my numbers. Right?
    Tucson, AZ
    In-ground Gunite
    20,000g
    Ubalr1, I believe that every new poster deserves a quick response, even if I can't provide the 'full' answer. There are folks here who understand chemistry MUCH better than I. What I know has been (mostly) gathered from reading a bunch of threads here, so I'm passing on second hand info to you.
    As for the 'results ending in '0' ', pool store testers seem to have a 'built in' 'sell chems' sub program in them, when I do a drop based test (like Ben's kit or the Taylor 2005 kit) I get results that are in increments of 10 - a pool store number that doesn't end in "0" is an indication of the 'selling software' kicking in. (this does not apply to cl or pH)
    While we're at it soda ash (a/k/a sodium carbonate/ soda ash is different from sodium bicarbonate (a/k/a sodium hydrogen carbonate) The Borax is a different way of raising the pH, but it doesn't affect the total alkalinity like soda ash does.
    I hope that this is at least slightly helpful, I'm thinking that a few of the folks who know more about chemistry will post when they see it.
    Tucson, AZ
    Thumbs up Re: First post - Trouble maintaining Chlorine
    Very helpful. Thank you.
    Tucson, AZ
    In-ground Gunite
    20,000g
    Waste is right on the money with his answer about soda ash vs. borax!
    Soda ash will increase pH and TA at the same time which, usually is not desirable. Borax will have minimal impact on the TA while raising the pH. The reasons are pretty technical and really of interest only to chemical nerds like myself.
    If you need to increase the TA don't buy the 'sodium hydrogen carbonate' from your (I am assuming) Bioguard dealer at the pool store. It is most likely commercial grade. USP grade (which is much purer) can be had at the grocery store for less money as Baking soda!
    If your pool store is using a colorimeter for testing with liquid reagents then it is possible that your numbers won't end in a 0, BUT if they don't calibrate the instrument on a regular basis then the readings might be less accurate then those from a test strip. IF they are giving you a computer printout either the meter is hooked up to the computer or they are manually entering the numbers, either way the clerk can (and sometimes do, I have seen it) change the numbers before the printout is run. You never know. If they are using strips with a meter I would suggest to RUN and NOT WALK out of there and not believe the results. Get in the habit of doing you own testing and take control of your water. You will be glad that you did! (And yes, I DO test water for people all day at work and sell chemicals!)
    Tucson, AZ
    [QUOTE=ubalr1]Lastest water test at local pool store:
    CYA 168
    TC 0.6
    FC 0.6
    pH 6.9
    TA 126
    Adj TA 76
    TH 527
    TDS 2100
    Cartridge filter
    Ahhh! This is confusing. What is the defference between Total Alkalinity (TA) and Adjusted TA. What I forgot to post originally was the Adj. TA as calculated? by the pool store. Adj. TA was 76. Which should I really be using to make adjustments.
    I found this formula online:
    Adjusted TA = TA - (Stabilizer X Stabilizer Factor)
    with
    Total Alkalinity Adjustment Factors:
    PH____Cyanuric Acid Factor
    7.0____0.22
    7.2____0.26
    7.4____0.30
    7.5____0.32
    7.6____0.33
    7.8____0.35
    8.0____0.36
    Following this formula (and extrapolating for my pH since it's just off this chart)
    I get an Adj TA of 90.72 (not 76 like the pool store)
    Adj TA = 126- (168*.21) = 90.72
    We're heading back to the pool store for another test since we added 12# of sodium hydrogen carbonate yesterday. Our test kit fo TA indicates not much change in TA.
    Tucson, AZ
    In-ground Gunite
    20,000g
    Tucson, AZ
    Things are improving.
    . . . . . .28-May. . . 29-May*
    CYA. . . .168. . . . . 110
    TC. . . . . 0.6. . . . . 0.7
    FC. . . . . 0.6. . . . . 0.7
    pH. . . . . 6.9. . . . . 7.2
    TA. . . . . 126. . . . .161
    Adj TA. . .76. . . . . 128
    TH. . . . . 527. . . . .450
    TDS. . . . 2100. . . .2100
    After 12# of sodium hydrogen carbonate. Adding chlorine now.
    Tucson, AZ
    In-ground Gunite
    20,000g
    Joliet
    Hi ibalr1
    glad you found the forum...hope you find it as useful as I have.
    I am a total pool noobie...so I'm asking for clarifications sake>>>
    How did you get your CYA to drop 58 points in a day?
    did you get the sample done at the same places? (no matter if with the same test kit...or from the same store)
    Did you partially drain and refill your pool?
    I suppose that's my largest question...
    thanks,
    dan
  1. First Post - ZERO Chlorine
    By donnah1301 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-24-2012, 01:30 PM
  2. No free chlorine, trouble balancing
    By sapphire in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2010, 07:48 PM
  3. On maintaining FC...
    By docsobeck in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2009, 08:52 PM
  4. Trouble Keeping Chlorine
    By mkamp1515 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 08:07 PM
  5. Maintaining Chlorine levels during early spring
    By Lenny in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-08-2006, 01:23 PM
