Thread: Intex AG Blow up ring problems
    Jul 2006
    Default Intex AG Blow up ring problems
    We have a two year old Intex 12x24 oval AG. The top surfaces of the ring have turned brown and this evening it cracked open. We are probably on the verge of a collapse. One thought we had is to use some type of expanding foam in it. It would take alot of it. What can I use to recondition the vinyl? Last winter we left it up and it appeared to work out OK. I had planned on closing it this weekend. It is a salt pool and we rarely have to do much to it. I live in Mid-Michigan
    Thanks for any suggestions
    Default Re: Intex AG Blow up ring problems
    I don't have any ideas for you, but just wanted to let you know your post is being read, and hopefully some of the folks that have good info will chime in shortly.
    Jul 2006
    Thanks Janet,
    I just patched the obvious split with a piece of vinyl and some 100% silicone. I did read elsewhere that some people have stuffed their ring with pool noodles. Interesting idea, if I could find them for about a buck apiece. I just went to the Intex site and there is no mention of conditioning the vinyl, should I have known about this?? My wife is looking for a warranty, I haven't found one yet.
  1. Intex filtration problems
    By teamwir in forum Intex-type Pool Setup & Operations
    Last Post: 06-20-2013, 04:04 PM
  2. Blow-up ring for Intex Pool solved!
    By drabarni in forum Intex-type Pool Setup & Operations
    Last Post: 06-18-2013, 04:12 PM
  3. Calciium problems in an Intex pool
    By justlane4 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-08-2013, 02:32 PM
  4. Blackish/Brown Sludge on Ring - Intex Easy Set
    By mstreeter78 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-13-2012, 02:14 PM
