Thread: How can I disconnect my pump?
    Jul 2012
    New York
    Default How can I disconnect my pump?
    I have a Pentair 340063 pump, new this year. I figured this would not be the most complex part of closing the pool, but there you go.
    It's plugged into a timer and upon dismantling the face of the timer, the pump doesn't have a finished 3 prong outlet, but rather bare wires that, internally to the timer, are hooked up with wire twists, so I don't want to do it there.
    I undid the plastic washer where the cable actually enters the pump housing, but didn't see an obvious way to deal with it.
    I am in NY and wanted to take the entire contraption and filter head indoor so no worrying about freezing with those.
    Thanks1
    Scottsdale, Arizona
    Default Re: How can I disconnect my pump?
    Can't you disconnect it at the wire twist ?
    Jul 2012
    New York
    Red face Re: How can I disconnect my pump?
    Quote Originally Posted by Phillbo View Post
    Yep! Despite fancying my intellect at times I also know other times I have the mental capacity of a cat. On a whim I asked my father in law to check it out and he had it disconnected right away. I think I was missing the necessity of the twisting action
