Thread: Can I have too much salt in my pool?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Can I have too much salt in my pool?
    The Intellichlor is built to protect itself from high salt so it will shut down past 4500 ppm. Since I take it the unit did not go into alarm, it should be ok.
    Also, it can take some time for the salt to full mix so you might want to measure again in a couple of days.
    Mark
    Apr 2012
    St. Louis metro area
    Thanks for the response. The Intellichlor did not shut down, but the Red "low salt" light was on briefly a couple of days ago. It has since changed to Green, indicating the salt level is okay. I wanted to be sure of my levels, so I have taken the advice of the forum and used the Taylor testing kits.
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
