Thread: Pool Closing Concerns
    Sep 2012
    South Eastern Utah, USA
    Post Pool Closing Concerns
    Its time to close my AG intex 32'x16'x52" 14,365 gal. pool. My ALK readings is and have been consistent at 140 , my pH is 8.0 and has been consistently so. My CYA is 70 my FC is currently 4.8. My concern: Can i close my pool with these readings? My water is crystal clear and has been since I started using the BBB pool care. I hate the thought of trying to fix something that does not appear broke. But, honestly....I just don't really know. This is my first year of owning a pool. Any help and/or advice would be greatly appreciated. Cordially YvonneSEU
    16x32 rectangle 14.6K* gal Intex AG vinyl pool; Household Bleach; Sta-Rite System 2 cartridge filter; Waterford Systems 1 speed pump; 8 hrs; Taylor K2006, HTH 6 way test strip; well; summer: none; winter: intex provided cover; android phone; PF:8.2
    Default Re: Pool Closing Concerns
    There is a stickied thread that talks about closing an AG pool. If you haven't already done so, it would probably be helpful for you to read it.
    With a CYA of 70, I would take the chlorine up before you close the pool. Take a look at the Best Guess Chlorine Chart in my signature below. A FC of 4.8 is flirting with algae with that CYA level. (By the way, just use a 10ml sample instead of a 25ml sample when you test. It will save on your reagents.)
    Sep 2012
    thank you, I am feeling less stressed about raising the chlorine level. Between last night and tonight I raised my chlorine level to 9.5. By looking at the best guess chart I see I can bring level up to 20. I have the polyquat ready to go, but my pump is a cartridge filter and it has no recirculate option. Instead of running the pump, can I run my pool rover?, its self propelled and will aerate the water while it vacuums. Is this an option? They way I understand the best guess chart, 5-10 should be my chlorine levels, up to 20 is shock level. I want you folks to know how much you are appreciated. Thank you again. YvonneSEU
    Sep 2012
    Thank you again. I will go forward with pool closing now. Thank you again.
    Y.
