Re: Using Bleach in the Pool
Tested tonight (had to go away for the w/e). It was 2 for chlorine. 7.4 for ph and the CYA was over a hundred. I had to use an old tube for the CYA test and the reading #s only went up to 100. I am guessing it was over 120 based on the spacing of the lines, but it is a guess. I will test again in the morning.
I have 9 gallons of 6% bleach waiting to go in the pool if necessary and can get more. The pool is slowly, very slowly, clearing (1.5 weeks after initial shock treatments), but is still cloudy, especially in deep end. No new algae has popped up. I can still see dead algae on the bottom.
