Cleaning inside of hoses for winter
Hi! I had great luck with your advice so have not been on the forum in the last few months. Too busy enjoying the pool.
I have a 3 yr old liner that is faded and has a few holes so will be getting a new one next spring. I have removed the pump and filter and she's plugged and covered and waiting for spring to drain it and replace liner. I cleaned all the skimmer parts and they came out good and soaked hoses in a bleach/water solution and noticed the inside of the hoses to my 2500gph pump which I installed new in mid summer of 2012 have algae in the grooves. Is there anyway to clean them as they are made much better than the old hoses I had with the 1000 gph pump and have the adapters for the newer 2500 gph attached. Really don't want to purchase new ones unless it's absolutely necessary.
Thanks.
Pool Puppy
15 ft Intex 3200 gallon agp. Intex GP53366EG 2500 gph pump with size B filter as of 5/21/2012. Used 1000gph pump before that for 2 yrs.
