Thread: Painting the Top Rails
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default Re: Painting the Top Rails
    Do you want to paint them in place to avoid the work of removing and reinstalling??
    I suppose you could sand them, then brush or roll them in place.
    Personally, I think the removal and reinstallation will be less work than the clean up after sanding, if you leave them on the pool.
    I would remove them, sand, treat them with a rust neutralizer, then prime and spray paint, (both sides) and reinstall.
    The quality and life of the job will only be as good as your preperation, so the extra elbow grease now, will give you more years without having to do this again!
    The thought of removing these old bent rails is daunting. How is it done, anyway?
    nj, usa.
    The cap that covers where the rails meet should be screwed on, and the rails screws will be under that cap.
    My pool has a single screw in the side of the upright securing the cap.
    Under the cap there are two screws on each rail end, screwed into the plate on top of the upright.
    Doubt there is much difference between pools
    Try getting one rail off, and see how it goes.
    But grab the Liquid Wrench, just in case !!
  1. Painting PVC
    By aammcc in forum In-Ground Pool Construction and Repair
    Last Post: 05-14-2011, 02:03 PM
  2. Painting Vermiculite - Possible ?
    By gtera in forum In-Ground Pool Construction and Repair
    Last Post: 04-26-2011, 10:22 AM
  3. We have a 23.5'x13.5' AG pool! Now how to fit top rails?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 08-05-2007, 06:28 PM
  4. Ladders and Rails
    By pogoaz in forum In-Ground Pool Construction and Repair
    Last Post: 09-27-2006, 03:58 AM
  5. Top Rails Bent Inward
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2006, 04:58 PM
