Thread: ascorbic acid treatment
    Default Re: ascorbic acid treatment
    I'm not sure you made any mistakes, though it sounds like you didn't complete the process, at least at first. There are 3 functional steps: re-dissolve the metal stains, treat them to keep the metals in the water and then EITHER remove the metals from the water (CuLator or calcium adsorption OR
    We've gotten several reports of sequestrants clouding the pools they were used in. This result is not consistent with the old Dequest / Monsanto data I have on HEDP. I'm not sure if the problem is that the products are not HEDP, or if they have something in them besides HEDP, or if the Monsanto data is in error.
    Can you tell me EXACTLY which sequestrant you used, and how much?
    Also, have you identified what metal is staining your pool (sounds like iron) and where it's coming from? Have you done the bucket test on your incoming or fill water, to make sure that it's not contaminated with iron or something else?
    Oct 2012
    colorado
    Hi pool doc.thanks for the response. The sequestering agent is Sparkle Conquest, manufactured by Alden Leeds Inc.. I added one quart per 20,000 gal.. total added was four quarts for 80,000 gal. I had an independent lab do water test on our supply water and pool water. The lab says that mg/L is the same as ppm (parts per million). supply water test is as follows: iron= not determined, magnesium= 5.38 mg/L, copper= 0.134mg/L, and manganese= 0.0232mg/L. pool water test is as follows: iron= not determined, magnesium= 35.8mg/L, copper=0.0047mg/L, and manganese=0.0111mg/L. what is the bucket test? I was not able to do direct reply and had to start another thread…thanks for your time…pooltech..
    Well, your test runs tell you that neither copper nor manganese are the problem . . . which probably means iron is.
    The metals bucket test is described in this forum section (Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions') and allows you to test for staining metals in your water in a non-quantitative, but more reliable manner.
    The 2004 MSDS I have for Alden Leeds Conquest reports that it *was* 60% HEDP, so I assume it probably still is. You might want to call A-L and ask, though. 1 gallon of 60% HEDP in 80,000 gallon is pretty high, and could cause problems with calcium > 300 ppm.
    (At least for water, your lab is correct that 1mg / L = 1 ppm.)
