Results 1 to 9 of 9
Thread: It's too easy being green
    mbar's Avatar
    Ashland, PA
    Default Re: It's too easy being green
    You have to keep adding chlorine - but you must be consistant. Don't let it drop down at all. Keep it at 12ppms, and keep the filter running 24/7. If you have a sand filter, you can put a cup of DE in the skimmer. You can also cut the leg off a pantyhose stocking and put it in the skimmer basket - it helps to filter out small particles. I opened my pool to a green swamp on Thursday. Using lots of bleach, keeping my filter running 24/7, and vacuuming everyday with a sock on the skimmer basket, a cup of DE in my sand filter, I now have clear water. It did take 3 full days to get completely clear. Have patience, and keep up with the chlorine. It will clear up.
    Northeast PA
    duraleigh Guest
    Hi, Jaybee,
    If you are seeing visible matter "blowing thru the filter" (i.e. back into the pool thru the return jets) you have a filtration issue.
    No filter, sand, de or cartridge, should allow anything visible to reenter the pool. Like Marie said, you have to keep your Cl level up (looks like you're still consuming just a tiny bit) but I think, if I read your statement about visible matter correctly, that your filter is the primary culprit.
    It was a good idea to brush up the stuff......but if your filter's at fault, it's a moot point.
    Des Moines, Iowa, United States.
    Well, I don't see particles that are visible individually, just a green cloud from the inlet when vacuuming. Does that make a difference?
    duraleigh Guest
    Quote Originally Posted by jaybee
    Absolutely. You should only be returning clear water to your pool. Check that filter. Are you backwashing?
    Yes, we're backwashing. We lost some sand out of the bottom plug during startup, I wonder if my sand level inside the filter is too low. I do have some additional sand and can add that to the filter. I was under the impression that a sand filter is incapable of catching very small algae particles, am in wrong about this?
    Your sand filter may not be able to catch as minute particules as a DE filter would, but you still shouldn't have anything visible returning to the pool. Check and make sure you have adequate amounts of sand, and it sounds like you may need to check and make sure that you don't have broken laterals (yes, I know, that means you're going to have to remove the sand that's in there to check). If all checks out, then you might want to take mbar's advice and add a small amount of DE to your skimmer to help catch what's getting through your sand. I have not done this, but a couple of our other moderators have and say it works well. Just make sure you keep an eye on your pressure if you do this.
    Keep in mind also that AG filters are frequently undersized for the pumps supplied, and once your algae is dead (yours isn't yet, if it's still green) it may take longer to filter it out of your pool than it would in a pool with a larger filter.
    Keep your chlorine level up, keep brushing, and check the sand in your filter.
    gregugadawg Guest
    Sand filters only filter to about 30 microns, a human hair is smaller than this 30 microns so yeah sometimes stuff will pass through a sand filter such as algae, this is why you need to vacuum to waste when you clean up an algae pool. Or buy a d.e. filter which has one pass filtration and cleans your pool up very fast.
  1. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  2. CLEARING UP A GREEN POOL, Movie magic or can it be this easy...
    By pbotz2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2011, 09:55 PM
  3. CLEARING UP A GREEN POOL, Movie magic or can it be this easy...
    By pbotz2000 in forum Dealing with Algae & Slime
    Last Post: 06-01-2011, 01:21 PM
  4. Why are things never easy... please help!!!
    By ellenicol in forum Pool Equipment & Operations
    Last Post: 07-02-2006, 09:45 AM
